im curious since i hear everyone say longtubes wont fit on our cars. what exactly is in the way and can something be done about it to fit longtubes? i mean they fit them on fox body mustangs and thats a totally smaller car. theres a custom header shop about 50 miles from me that said they could make me some custom ones that would fit but it would probably cost 5-600 bucks. im willing to pay if thats the only option, and maybe some other people on here would be interested ( could probably get a better deal on them if they knew they were going to make more than one set) if they really can make a longtube header to fit our cars.
why is it that longtubes dont work on panthers?
Clearance problems with the crossmember and the steering stuff mostly. I remember Tom (gmgt) did some test fitting with I think Torino headers a while back, there may be a post detailing what hit where. Duceandahalf has mid-length ones on his car, and he customized them to clear properly. Might want to look up his posts on the subject as well.86 Lincoln Town Car (Galactica).
Originally posted by 87CrownVic View PostIf that custom header shop does quality work, you may want to just get them done there. That is a severely cheap quote, I haven't found anywhere in WI or IL to fab headers for less than twice that...
tom tried a set of 72-79 torino chassis headers for a 302......would not clear the crossmember or the upper control arms.......tom also tried a set of ford truck 302 headers.....i do believe they failed badly also
Originally posted by Lincolnmania View Posttom tried a set of 72-79 torino chassis headers for a 302......would not clear the crossmember or the upper control arms.......tom also tried a set of ford truck 302 headers.....i do believe they failed badly also
i had longtubes on a 73 cougar.......never again.......the starter used to get hot and burn up from the heat of the headers and i would have to remove the header to change the starter........damm gaskets used to blow all the time...
when i first did some looking at headers for mine i measured up the headers on my 74 E-300 and compaired them the car, the drivers side header would have fit, but the passenger side would not fit due to the starter and frame clearance.. also they would have hung below the frame about 4 inches.
But i just got done tweeking a set of mid-length headers for a 66-77 bronco to fit my car. had to modify the shift linkage.sigpic
