Here is the situation. I need to decide if I should go for it or cut my losses.
My $400 beater colony park which is my daily driver (actually more like a $1400 beater after tires, new shocks, a starter, exhaust work, throttle senser and other odds and ends) was pissing coolant from the back of the engine.
First guy that looked at it said if was the head gasket. Second guy (who worked as a ford mechanic for around 20 years) says it is the lower intake manifold gasket.
Here is the thing. At first he says it is probably not worth it to do the lower intake gasket ($400) because of the "overall condition of the car" because the head gaskets are "leaking a lot of oil".
To do the manifold gasket and the head gaskets is $1200.
Wondering if I should just cut my losses. The car does have 196K on it.
But I really feel that if I dump it now I will have wasted a bunch of money to drive the car for only a few months. But on the other hand, If I go for the head gasket job will I be just throwing away good money after bad?
Or, do I just go for the lower intake gasket in the hopes that will keep it on the road without much more for the next 6 months or so.
Maybe I should get a horse.
