i was wondering what is the size of the rear diff. on my 88 grand marq. i know i might sound like a complete idiot, but i need to know? as well as whats the easiest way to convert from efi to carb? i appreciate it.
rear diff and carb conversion????
Any special reason you want to go to a carb? I personally would not suggest it unless you really need to do it. I'll also admit to not liking carbs so I generally try and persuade people to keep the EFI if at all possible.86 Lincoln Town Car (Galactica).
I love carb's. There not as much trouble as some people make them out to be. I found it to be pretty easy to do the swap. But then again I didn't have to fuss with the kick down. I'm with you though I hate clutter especially wires so any thing I can do to get rid of some I do.1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
Its actually about the same work to convert a CFI car as it is to do an EFI car. Despite the injector setup being different, not much else is.86 Lincoln Town Car (Galactica).
Back to ANSWERING THE QUESTIONS ...........
The main components of your carb swap are mostly the obvious: your favorite four-barrel (the 500cfm Edelbrock 1404 is a great option); your favorite low-RPM dual-plane intake such as an '83-'85 Mustang intake, Offy Dual Port, or the ever popular Edelbrock 2121; and an ignition system, usually consisting of a Duraspark II distributor with a gear that matches your camshaft (steel for rollercams, AutoZone gives you a choice) and either a matching DSII box or your favorite aftermarket CD ignition box. At this stage you'll also be making decisions about what emissions controls you want to retain and how to do it.
People have used several different approaches for fuel. The most radical (and what I ended up doing) is to swap in an early-model fuel tank for a '79-'82 car along with the matching pickup/sending unit and mechanical fuel pump. It's also possible to leave the electric pump in the tank but disconnected and use that as a pickup, or else to remove the pump and connect a pickup hose to what was the pressure line leaving the tank. Yet other people have chosen to retain the stock in-tank pump and use either a regulator or even a plain T fitting to return unneeded fuel via the stock return lines.2012 Mazda5 Touring | Finally working on the LTD again!
