miss/stuttering
    miss/stuttering
    my car has a miss/stutter and it is very iratic, not in pace at all sometime it does it , then it doesnt.. i just did a tune up yesterday and the back 3 plugs on the pass side were almost white . so the question is do i have an o2 or an injectior problem, the o2 are about 2 weeks old. help i"m going insane and dont really have alot of extra cash to be just repacing parts
    sigpicTHE H.I.D MASTER
    87 mercury grand marquis
    88 crown vic lx
    89 mercury colony park ls (sold)
    89 mercury grand marquis (sold)
    00 ford crown vic lx hpp
    03 mercury marauder aka punisher (sold )
    scan for codes?
    last time fuel filter was replaced?
      X2...fuel filters are cheap and easy to replace! Also try a bottle of fuel-injector cleaner, next time you gas-up.
      '79 Continental Town Car
      '90 Crown Victoria LTD
      '94 Crown Victoria
        EFI plugs normally run fairly white, so that might not tell you anything useful. Code scan will be more useful if changing the filter doesn't help. O2 sensors are seldom the cause of a lean or rich code, more often than not, they are providing the correct information and telling you something else is wrong.
          filter is maybe 6mo old and the plugs are considerable differant im use to seeing specaled white on them over the years these were white
          88 crown vic lx
            i just bought some injector cleaner and im going to try it and i'll get a new filter just to be safe there only like 10 bucks
            88 crown vic lx
              check for codes
                i checked for codes got egr and tps , there both new so i went and swaped them out at advanced auto and still misses , got some tb and choke cleaner and sprayed the manifold for a vac leak and nothing. so im guessing im going to just replacing the injectors.
                88 crown vic lx
                  your plugs should all be fairly consistent in condition.. if 3 of them looked alot different than the others they could have been gapped different or indicating a lean condition.
                    that thought came across my mind to i checked them all @ 35 just got done doing the fuel filter and took it for a good drive and no change at all
                    88 crown vic lx
                      You've got them gapped too small. It should be .052 I believe. Its on the emissions sticker under the hood, right next to where it specifies the plug type.
                        ive had them gaped at 35 all 5 times ive changed the plugs, and it has never done this before
                        88 crown vic lx
                          ok im lost , i feel like im chasing a ghost , i changed the injectors and regulator then put in new plugs and even set them to oe spec instead of 35. and the car ran good other than it surging because i cracked the egr vac line. i fixed it and the car runs great then im on my way to work this morning and sitting at the light it stutters/misses again ... so now what im losing my mind . and contaplating just parking it in the gurage and letting it rust in peace.
                          88 crown vic lx
                            have you disconnected the battery since replacing sensors? might wanna try that and let it relearn everything.
                              yes did try that a couple of times once when we did the injectors for a couple hours and i onhook it over night on friday before the injector swap.
                              88 crown vic lx
