edlebrock intake manifold Q's
    i just bought a 2bbl edlebrock manifold w/ egr spacer. (cool stuff but pricey) im slowly trying to upgrade for my cfi 85 cv to a cfi ho. i know i need e7 heads, harness, and cams ect.. i wanted to know how much hp does my cfi lopo motor aready have? how much hp could the edlebrock intake bring in a lopo w/out ho upgrades.
    sorry for the dumb q's but im addicted to this cfi stuff for now. untill atleast i can afford a 6 grand 302/375hp efi cobra motor.
    thanks guys in advance
    67 Ltd tudor
    67 Ltd 4door
    85 Ltd 4door
    the 85 cf1 ho had e5 heads and was rated 180hp/280 ft lbs torque that edlelbrock intake might give you 10-15 hp over the stock intake
    did you find a 85 mark7 lsc cfi unit and ecm yet? you will need the 85 ho cam too, but i always suggest buying a new flat tappet cam and lifters
      the freaking CFI's had more horse power than the EFI's???!!?!?
        not yet, im still looking in the junkyards for a mark7 cfi unit and ecm. san diego doesn't have many mark7s. i might have to go junkyards up north near L.A. or just simple e-bay.
        *stupid q
        does summit have 85 mark7 lsc cfi unit and ecm?
        67 Ltd tudor
        67 Ltd 4door
        85 Ltd 4door
          *stupid q
          no these must be sourced used
            HO CFI, yes. non-HO CFI was I think 155 hp.
              More like 135, I think. Stock EFI single in 91 was 150, so I sincerely doubt that the cfi made more.
                the 85 cfi non ho cars put out 155 hp.
                  yup, depends on the year. 85 had better heads. 84 was I think 140, 80-83 was 130 or 135. Torque production on the other hand, the SEFI motors make more. I don't have figures, but if you've ever driven a properly running 85, then get into a properly running 86+ you can feel it. The torque figures are more useful than horsepower numbers to be honest. HP was a concept developed 175 years ago to sell steam engines. Its just a math function of torque and RPM so you may as well just use those figures directly
                    I think i found a web site that has mark 7 ecu. im not sure about a lsc cfi unit though... but tell what you guys think.
                    also what is the difference between a vin M and a vin F?!
                    http://www.racepages.com/products/in...87+11949&Nty=1
                    thanks in advance
                    67 Ltd tudor
                    67 Ltd 4door
                    85 Ltd 4door
                      I found this as well
                      A1 Cardone Electronic Control Unit
                      1985 Lincoln Mark VIIA1 CARDONE ENGINE CONTROL COMPUTER, REMANUFACTURED
                      FITS (Engine/Chassis) 1985 Lincoln Mark VII $125.87
                      1985: LSC; 8Cyl 5.0L GAS, FI, VIN "M";
                      am i looking for a ecm that has LSC on it ?! or it another component all together ?!
                      sorry for the dumb q's but i just want to make sure i get the right parts,
                      Leo
                      67 Ltd tudor
                      67 Ltd 4door
                      85 Ltd 4door
                        Vin code M is the 85 LSC with the HO motor. The ECM itself won't say LSC on it.
                        Vin F is the non-HO motor, should be what you have now.
                          good, good... then i found one of the right parts im looking for, vin "m"...
                          do i 'need a lsc cfi unit' or could i just upgrade the one i have already? found a junk yard with lsc cfi. no good. though.... front end smashed to hell...
                          also are these the two essential components + cams, heads, for the Ho upgrade?! or is there alot more ?!
                          thanks
                          67 Ltd tudor
                          67 Ltd 4door
                          85 Ltd 4door
                            I think the heads may actually be the same for HO and non-HO in 1985. You can swap the heads for something better, but unless you're going to say a GT40 type, I doubt you'll notice much difference. There isn't a lot of change between the E5 (1985) head and the E7 (1987 truck and HO) head.
                              :confused: Do i 'need a lsc cfi unit' from a lincoln mark 7 or could i just upgrade the lopo cfi unit?!
                              stupid q
                              whats the difference between a lopo cfi unit and a lsc unit obviously the lsc is an ho but what components does the ho have that the lopo doesnt have
                              67 Ltd tudor
                              67 Ltd 4door
                              85 Ltd 4door
