You know, sometimes the machine shop can get you a better deal on the parts. Sometimes...
Rebuliding the lo-po
Are you going to reuse the lopo cam? I would go ahead and do a cam swap while the motor is apart, find an Explorer cam. I really like the Lunati Vodoo cam in my Silverado.88 Town Car (wrecked, for sale)
Originally posted by Pesty351 View PostUmm.. Might be a dumb ? but were 84's roller blocks or not? I thought they weren't but if that is the case whats with the xxx? BTW the machine shop wants ~650 to refresh the shortblock.86 Lincoln Town Car (Galactica).
Ok I was apparently miss informed about the xxx thing. As far as cam selection I going to go with something a little better suited for a small car.1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
The local machine shop with a good reputation told me ~$650 for a short block rebuild. Do you all figure that's a decent price or should I keep looking?1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
Is that all the machine work plus assembly, or the machine work plus the engine kit, and you put it together? Seems to me I paid around 600-650 for the machine work and the engine kit, and I put it together myself. That was including a bore job and a set of pistons though.86 Lincoln Town Car (Galactica).
I paid $175 to have my crank turned .010 and $250 to have the shortblock assembled here in Raleigh, NC. Parts were another story...1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
Thats parts, machine work, and assy.1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
I'd say thats not too bad then. Including new pistons, or would those be extra if needed?86 Lincoln Town Car (Galactica).
Extra if needed. I'm hoping with the way the walls look that they don't need replaced.1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
Ok the shop cut there price a bit 750 with new pistons and everything should be done this week. Wahoo!1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
It's done now I just need to put it the rest of the way together. It ended up .30 over on the pistons and 10 on the crank. All I have left is to pick a cam and to figure out what push rods to use.
very nice!
