How much oil is too much?
    Good advice. My '88 GM and '89 Mustang both read overfull with 5 quarts in the pan. I scribed the other side of the dipstick and called it good.
    2003 Lincoln Navigator
    2001 Grand Marquis
    1985 Camaro, 12.52 @ 114 MPH
      That makes sense, I know I only put 5 quarts in.
      Thanks
      2000 Grand Marquis LS
      Mercury Owners Group member
        My 89 is the same fill it with 5 qts and it is over the full mark. I have had it changed at the Ford dealer and it comes out over the full mark from them too.
          haha if you want to hear a funny story when i first got my car i decided i would be cool like that and change my oil...... little did i know there are two drain plugs... so i guess i drained like a quart or two from the front and added like five )= i even drove it 20 miles back to my house before i realized it was acting kinda sluggish
            doh... introduce yourself to the forum http://www.grandmarq.net/vb/forumdisplay.php?f=24
              From what I've seen:
              '79-87 Dipsticks are correct
              '88 and '89 Dipsticks are off by a quart (they read a quart high when you put in five quarts)
              The low mark is the same, the high is off. I swaped the between my '87 (sorry LTDMan83) and '88 so I could have a good dipstick in the car I drive the most.
                HAHAHA, I noticed that dipstick had different markings on it, from the original '79 to '87 dipsticks that I have seen. I just figured it was probibly from a truck 302.
                I replaced it, and It now lives in my Merc's HO engine, which only takes 4 1/4qts to be correctly full, so it actually is right for that particular engine, lol.
                  HO motors take 5 quarts with a filter change, same as a lopo. Ignore the dipstick, just put the right amount of oil in there and make a new scratch mark on the stick.
                    This one actually does take 4 1/4qts, as it has a custom Oil Pan. Someone dented in the rear sump of the pan with a floor jack, removing a little over .75 of its capacity. It doesn't leak, and the drain plug is fine, so I'm not really worried about it. The 88+ dipstick just happened to match this oil pans "modified" capacity, lol.
