engine lights
    engine lights
    whats the diffrence between the red and yellow check engine lights?
    i assume the red is hooked up to really important things like water temp and oil pressure and the yellow is just all the other BS?
    1989 Grand Marquis GS
    the red check engine light is commonly refered to as the replace engine light........either oil pressure is under 3 psi or temp has exceeded 250 degrees to make the light come on
      haha ok, hopefully that one never comes up anytime soon then
        tony the red engine light come on with low oil pressure or if it overheats
        the yellow check engine light is for when there is a proplem with the sensors or the computer
          i get a blink out of the yellow one every once in a while. i didnt think it was anything important
            mine only does that when its really cold outside, anyone have suggestions?
            What happened here?
              I'd worry if those lights came on....however, I'd shit my pants if these lights came on in the dash:
              Explore UFO sightings and mysterious aircraft with Phoenix Lights Network. Discover intriguing stories and share your own. Visit now.
                check it for codes, it should explain the yellow lamp. I was getting that out of my Mark VII, turned out to be a EGR valve with a leaky diaphragm. It could be a whole lot of things though, no way to tell without pulling the codes.
