Question... How do you get the transmission shifter linkage connection under the hood to disconnect? When I bought the new steering column for my 84 "Baby" LTD... we had a heck of a time getting the column out, because of the shift linkage. We tried prying it apart at the connection, (where the plastic or nylon bushing is) figuring it would just pop apart... no go... we pryed and pryed, it would not budge! We ended up sliding the "bellcrank" off of the end of the shift linkage shaft... (It has a lever type setup that slides on the end of the gear shift shaft, under the hood.) This in turn has the connection joint that connects to the linkage going to the transmission...
Shift tube linkage... Any ideas on how to seperate this connection?
Here you can see how the shift lever came off of the end of the shift tube... But it was a bitch getting it off... we hooked the lever on the fire wall, and pulled on the steering column, from inside the car, sort of banging it on the side of the hole in the firewall, until it seperated. I do not think if I have to separate the shift linkage this way that it will go back on very easy... not to mention in such limited space to work... The shift tube is the small shaft.
The new column... leather wrapped steering wheel, and cruise and tilt on this one--- it even had the key in the ignition, so pulling the old lock set to put in my new lock set should go pretty easy... hopefully... (I bought a new lock cylinder, and had it keyed to match the rest of the locks... since all are the same on a police car....) Going back next week for all of the servo, etc. to hook up the cruise...
