Hey ahm tryin to replace the vale cover gaskets on my Wagon the passenger side does any one have the diagrams for the engine so that I dont screw up to much? :chainsaw:
Help Replacin The Valve cover Gaskets
Replacin the Valve cover gaskets
Well since I am not that technicaly inclined in the engine part of my ride and all other options have since failed and I trully dont want to make a serious mess of things I figured it would be easier to see if someone had the haynes or chilton diagrams that they could scan in as an attachment so that the warwagon could make war not smoke like hippies at woodstock. :chainsaw:I declare WAAAAAAAAAAAAAAAAAARRRRRRR on all imports an GM.Smoke em if you find em,make them fear the sight of the panther platform.
Nothing handy, but just be careful with the hoses on the back of the upper intake. Take a picture if you don't feel comfortable with it. Honestly you don't need to disconnect them, just unbolt the upper intake, move it aside, then remove the valve cover. Probably would be a good idea to replace that upper intake gasket while its apart too.86 Lincoln Town Car (Galactica).
