ok so that means that its ok for it to be a little below stock timing or does that mean something else is off?
Timing off?
your balancer may have spun putting the timing marks off
oh well whatever it is, i guess i fixed it.it wasn't right on 10*,it was a little bit lower, but the car is running fine with it like that.it'l just have to stay this way until i can figure out what the real problem issigpic-The Crown(Kodiak)1989,150K Miles,5.0LOpo,autolamps,slicktop,power windows and locks,yet still not good enough to be LX:confused:
Yes its fine to have the timing retarded to under 10*. It may make it a little sluggish but thats better than pinging. Mine was at 8* when i checked it before i set the timing and it was runing fine.
'90 LX 5.0 mustang
Big plans
When you connect the spout connector, the timing will advance. Its normal.86 Lincoln Town Car (Galactica).
Originally posted by 1980c10 View PostYes its fine to have the timing retarded to under 10*. It may make it a little sluggish but that's better than pinging. Mine was at 8* when i checked it before i set the timing and it was running fine.sigpic-The Crown(Kodiak)1989,150K Miles,5.0LOpo,autolamps,slicktop,power windows and locks,yet still not good enough to be LX:confused:
