Hi everyone,
The oil pan gasket of my 89LTD Crown Vic 5.0 is starting to wear out. Small amounts of oil haved started to leak & oil is dripping from time to time from the front end of the engine.
I guess it is time to change the gasket....
Off course I wouldn't be here if it was as easy as the valve cover gasket swap (which by the way isn't that easy either, due to intake manifold, cooling system & friends generously installed all over them).
I started to check my manuals and it seems to be a sh... job to do: there is just no way to get the pan out of under the engine without ... simply... unscrewing/unbolting everything and lifting the engine out!
Well, if it has to be done, it has to be done!
I just wanted Your advice/tips on this, because I don't want to start a job that I can't finish - and which could ruin my car in the end.
Thanks for Your help!
Magicmike
Magicmike
