I am thinking of forking over $1647 for the AEM standalone computer for 5.0L cars. I hear I can delete the distributor and use newer individual coils for each cylinder and greatly improve power and gas milage. With this price, I am hesitant, but I could create the ideal Panther. Anybody ever buy one of these or mess around with it?
AEM standalone for 5.0L
Originally posted by turbo2256b View PostNo but I have used the Electromotive system on several engines.1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
Originally posted by Grand_Marquis_GT View PostWith megasquirt you can do it for a LOT less.1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
you can do the same with an explorer eecv and a tweecer for much less. you also need to figure in the dyno tuning and all of the other stuff. its not cheap and its not going to make any more milage than any other piggyback. especially on a near stock motor. that box cost more than my crate motor. Ive made a ton of power with the tweecer on my car for the 400 bucksBuilder/Owner of Badass Panther Wagons
You can also buy complete Megasquirt harnesses so you don't have to hack up the stock one. I imagine any real stand-alone engine management system is going to provide it's own harness, or involve extensive mods to the stocker. If you go distributorless, the only practical way to do that is to replace or at least supplement the stock harness with one to run the coil packs. In practical terms, an all-new harness would give better fit.
1987cp: yes, that would be Megasquirt, though systems are available so you don't actually have to solder the board together and make a harness yourself if you don't want to.
I have to agree with mrltd though, unless you're going really radical, there isn't a big atvantage to a full stand-alone ECM vs something like a tweecer and a stock ECM and harness. Distributorless ignition is sort of neat, but unless you've got a hell of a motor, its not that much better than a conventional distributor. You do get more voltage to the plug, but on mild motors, thats not going to do much for you in a practical sense.86 Lincoln Town Car (Galactica).
for the kind of money you are talking about, I think this is a much better kit.
Most applications dont require tuning.
Yeah i built it when i was into the whole street racing thing. it was a regular 2.0L engine but i had it sleeved and high rise pistons for a mopar 318 where added. Also a custom grind cam, 34lb injectors, titanium valves and retainers with, dual valve springs. the Intake system is composed of 4 oem style 48mm tbs machined down and mounted one per cylinder. unfortunately the car doesnt idle below 1500rpm and the front wheel drive setup is uncontrollable. not to mention the complete destruction of cv joints. So it has been sitting until i can get all the parts i need to make it rear wheel drive. Sounds beautiful at 10krpm.
Originally posted by portdizzal View PostYeah i built it when i was into the whole street racing thing. it was a regular 2.0L engine but i had it sleeved and high rise pistons for a mopar 318 where added. Also a custom grind cam, 34lb injectors, titanium valves and retainers with, dual valve springs. the Intake system is composed of 4 oem style 48mm tbs machined down and mounted one per cylinder. unfortunately the car doesnt idle below 1500rpm and the front wheel drive setup is uncontrollable. not to mention the complete destruction of cv joints. So it has been sitting until i can get all the parts i need to make it rear wheel drive. Sounds beautiful at 10krpm.Builder/Owner of Badass Panther Wagons
