Engine Knock
    I know right?
      now you need less restricted exhaust manifolds... do i hear headers being added soon?
      Addicted to 86-87 Panthers
        Here's a quote from Wikipedia on what all is in a catalytic converter:
        1. The core, or substrate. In modern catalytic converters, this is most often a ceramic honeycomb; however, stainless steel foil honeycombs are also used. The honey-comb surface increases the amount of surface area available to support the catalyst, and therefore it is often called a "catalyst support". The ceramic substrate was invented by Rodney Bagley, Irwin Lachman and Ronald Lewis at Corning Glass for which they were inducted into the National Inventors Hall of Fame in 2002.
        2. The washcoat. In an effort to make converters more efficient, a washcoat is utilized, most often a mixture of silica and alumina. The washcoat, when added to the core, forms a rough, irregular surface which has a far greater surface area than the flat core surfaces, which then gives the converter core a larger surface area, and therefore more places for active precious metal sites. The catalyst is added to the washcoat (in suspension) before application to the core.
        3. The catalyst itself is most often a precious metal. Platinum is the most active catalyst and is widely used. However, it is not suitable for all applications because of unwanted additional reactions and/or cost. Palladium and rhodium are two other precious metals that are used. Platinum and rhodium are used as a reduction catalyst, while platinum and palladium are used as an oxidization catalyst. Cerium, iron, manganese and nickel are also used, though each has its own limitations. Nickel is not legal for use in the European Union (due to reaction with carbon monoxide). While copper can be used, its use is illegal in North America due to the formation of dioxin.
