Engine Knock
    recycle your cats and take the $$$$
    What happened here?
      I wanna see what was inside those cats lol. Sure made alot of racket.
        Me too mang.
          The original cats from the '79 had little chunks of catalyst falling out.
            they probably got all plugged/burned up while it was running funky... it might run much better with the new cats too!!
              cant really get any good money for toasted cats either.. you sure it isn't just the heatshield? i remember mine making some racket when i first got the car and i just peeled the heatshield off.
                Pretty sure they're dead, drivers side is partially clogged, back pressure at tail pipe is weaker than passenger side, and I think that's not as strong as it could be either. Out of curiousity, where's that damn platinum in the converter?
                  In the honeycomb brick like thing, the part thats probably broken up and melted in yours. Its part of the alloy used to make the converter.
                    What else is in that alloy mang?
                      stuff that will make you dead
                        I've breathed in soo much of that dust over the years from punching cats. Clear my throat and have crunch lougies. Loogees, fuck I dunno how its spelled but you know what I'm talkin bout.
                          no idea what else is in a converter, probably all manner of nasty shit. The amount of platinum in a converter isn't very great, but it happens to be a very valuable metal. The brick itself looks like a ceramic, so I'd actually expect the metals to be somehow blended in with the ceramic.
                            I have good news for everyone. After putting the car on the lift, with it running, I found it not to be the engine, but actually the catalytic converter. It's actually something inside it that rattles. I will be getting new cats tomorrow, and I will replace them on Monday. Those converters were kinda clogged anyway, plus I almost failed reinspection because of them. Thanks for all your input guys.
                            Does this car have two cats, or four? If it has four, and the upstream pre-heater disintegrated, then the downstream convertor is also bad, being plugged with brick material...if the downstream convertor is bad, or if there are only two convertors on the car, then most likely, the muffler on that pipe might also need to be replaced, due to brick material going straight into the muffler...just something to think about.
                              The brick shit is still in the catalytic converter. I just swapped them out today. Nice and quiet, and equal back pressure out of both the tail pipes. My fuel economy has increased slightly, the car is more responsive, and it doesn't smell like ass.
                              I had the 4 catalytic converters. Now basically my whole exhaust is new.
                                :woot: Nice John
