So my tranny is elevating its level of stupidity. I went outside this morning to go check the fluid level as it was acting odd last night. So I start it up and put it in revers to go put it in the garage.....It engages but does nothing. Then I push the gas it lurtches back and then foward, then back again. It continues to act pretty damn stupid untill it warms up. Once it warms up the only issue I have is when I come to a stop at a light ore something it doesn't want to drop out of 3rd, and sometimes it will stay 2nd even for the takeoff.
So I'm going to put some Slick50 in it and see if that helps, if not I really don't feel like working inside of my tranny again. I'll prolly just go get a new wide ratio trans that is already built up, and has a warranty. I've seen them as low as $900, with a 12month/10,000miles warranty, new. Maybe I can find that again. I'll let you all know how the slick50 does in it either way.
Oh, P.S. the fluid level is perfect.
