Coolant Leak
    Coolant Leak
    Help! My '91 Marq is leaking coolant at the rear of the engine and I'm having trouble determining the source. Here's what I know: there's no leak when the engine is cool (thermostat closed) but it's a fast drip when it's warm; it seems to be coming from between the engine and tranny in the area near to the O2 sensor on the driver's side; there's no coolant in the oil; the car hasn't overheated.
    Any ideas?
    well, unfortunately there are multiple possbilities. The intake itself, the coolant lines that go to the egr spacer, the heater hoses.....
      Thanks for your quick reply mrltd. I found the leak. It was one of the hoses going to the throttle body. Hard to see but easy to fix. Case closed!
        It usually is those lines, many people forget to replace them.
