-Since I am off from school and bored, I decided to play with the burnout car a little today. It has been running like crap for quite some time now, and is virtually un-drivable. It will not idle worth a shit.
-I bought a whole bunch of tune up parts (the usual stuff), and I am also going to change the horrendously leaky VC gaskets. After I pulled the upper intake off, I can't seem to figure out where one vacuum line went. Under the manifold, one line runs to some emissions BS on the PS front corner of the car. Where does the red striped vacuum line directly behind that line (under the manifold), go?
-Also, since I know little about EFI stuff, what might be causing my shitty run condition? The plugs are totally black, if that helps at all. The EGR valve may be fucked up, but will that make the engine run like crap? I believe it is stuck closed.
-Should I just buy new oxygen sensors, an IAC, TPS, MAP and EGR valve?
-Could a vacuum leak be causing this issue, or is it a more tell tale sign of something else. It is extremely choppy, and will not stay running for long when you let your foot off the gas. Also, the charging system on the car does not work at all. Could low voltage be the issue (I always have a good charged battery, and have never had this running problem in the past)? I am going to do a 3G conversion when I can get a JY alternator.
-Finally, I am going to put Mustang HO factory headers on the car, with stubby down pipes (maybe up to under the front door), so that I can put the oxygen sensors in them. Nothing after that. Is this going to cause a run problem? I am not concerned about performance, just noise, and I want it to run right...
Any insight would be cool. Thanks folks.
