Not sure where this should go but...
I have a Magnaflow muffler on the car now, just for the sound, and in hopes of covering up the annoying exhaust leaks in the Y pipe(Air injection pipe, and where the pipes Y are both leaking) I have a set of stock Mustang headers as crappy as they are.
My question is, If I use the catless H pipe from a Fox body will it fit under the car? Here are the spintech mufflers I am thinking of
Basically the same exit style but I will just get the mufflers and weld up the pipe as needed to fit them.
