car falls on face at full throttle...
    Normal driving, no issues. But when you put it to the floor and it gets higher up in the range, it just falls right on it's face and gags pretty bad.
    I originally thought the TPS had a dead spot higher up in the RPM range, so I finally pulled it yesterday and tested it. Tested fine.
    I've decided to replace my fuel pressure regulator, as it acts as if it's not getting enough fuel. It has a new fuel pump, fuel filter, and fuel pump relays so I don't know of too much else that could be causing it to act like this. I replaced all of them back in spring. It also has under 5k on the plugs, wires, cap and rotor. Under 2k on it's new timing set.
    Any ideas, or directions of where else I should look? I want this thing running top for spring when I get her back off of storage insurance.
    Valve float is pretty common on these engines when you go into the upper RPM.
      Still could easily be fuel filter.
      What RPM are we talking about. "High" rpm on these cars is 4500 rpm
        Feels like it's around the high 3's and low 4's. Sometimes it's not as bad as others too.
          Fuel filter would be the first thing I'd change, especially if you haven't been driving the car much lately. Ethanol fuel sucks up water pretty badly, and water will all collect at the fuel filter.
            I'll try that then. I'll take back the pressure regulator and get a fuel filter.
            Hell, for the amount of work it looks like I'll need to do to put on the regulator... might as well throw a 4bbl on there lol.
              if its not fuel related id head towards ignition problems. bad distributer, advance not kicking in after 3k.
                No advance mechanism on a CFI car other than the electronic stuff built into the computer. Nothing inside the distributor moves, other than the rotor itself. Its just a stationary pickup and the reluctor wheel.
                  so i guess htat elimintates any sort of advance besides the duraspark nonsense?
                    No duraspark either, same distributor and ignition system as a SEFI car. It uses a TFI module and the computer electronically controls the timing.
