Slight Jerking At Constant Speed
    Hi guys. I have been noticing a slight jerk when I'm at a steady speed. It's quite noticable on a flat road. If I give it any gas, it will go away. It's just a constant speed thing. I'm wondering if it's a clogged fuel injector or something. I'm having my mechanic perform the inspection so I can have it passed. Any ideas what might be causing the jerking?
    Bad plug or wire probably.
    1989 Grand Marquis LS
      Wires and plugs have been replaced. The car did this before I replaced the plugs and wires.
        It could be a clogged injector. Did you change the cap and rotor with the plugs and wires?
          No, I didn't. But I vigorously inspected the cap for cracks. I didn't see any.
            Sometimes they get tiny where you cant see em. Id swap the cap and run some injector cleaner through it.
              I was going to have him do that, if it doesn't pass right away. Run the injector cleaner that goes right through the fuel rail.
                Hi 86VickyLX
                Over advanced ignition timing.
                Regards
                Dereck
                President and founder of The Turbine Wheel Appreciation Society and Little Debbie Cake Connoissuer
                  Originally posted by Dereck View Post
                  Hi 86VickyLX
                  Regards
                  Dereck
                  Over advanced? It's set at 10* BTDC, so I should have it retarded? It smells a tad rich already.
                    are all your mounts good? trans/engine? have you fiddled with tv pressure? was it set correctly with a gauge?
                    p.s. you should try slightly jerking it at varied speeds..
                      All mounts are fine. Transmission has been rebuilt, and TV pressure was set by the shop.
                      It does the same thing at higher speeds too. Constant speeds mind you. It's more noticable at like around town speeds like 25.
                        my car used to do it too, i wish i could tell you what fixed it but it went away on its own. that or i just happened to change out what the problem was through the years
                          mine did that for a couple years but seemed to stop after i changed a bad ignition module.
                          can't swear it was related, but its been fine since.
                          good luck, Bill
                          s265.photobucket.com/albums/ii208/brokebill/
                          "Ain't we gonna bury him ?"
                          "Buzzards gotta eat same as worms."
                          ----outlaw josey wales
                          (88 LTD Crown Vic LX-Ruby)
                            good luck, Bill
                            Who knows. This car is weird. I wouldn't be surprised if it was that. But normally, aren't they either good or bad? Not like some midway point?
                              Mine did the same thing. Never really bothered to fix it since I'm doing a motor swap anyway. But I did have an idea. When I pulled the old motor out the timing chain had a ton of play in it. I don't know if maybe the cam timing was jumping around. Just a thought.
                              1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
