vacuum rerouting
    vacuum rerouting
    i want to tranfer vacuum lines from a lopo manifold to a explorer
    manifold since there different how should i do this i still want to use the vacuum tree from the lopo.i want the explorer manifold to have the same look as the lopo manifold
    You can't use the lopo tree on the Explorer. It doesn't thread in. You'll have to get creative with the vacuum routing. There is enough connections on there but you'll need to move some lines around to make it work.
      so all the holes on the explorer manifold are for vacuum then.got any pictures so i can use as a guide
