I am looking to replace the oil cooler lines on the '85. As you may or may not know I am replacing the motor, and EVERYTHING is getting replaced, including these leaky bastards. I was going to make a set from all new -10an parts, but that is a very expensive option... Those -an fittings and braided hoses are rather expense even from Summit. Does anyone know of either pre-made hoses, or possibly some NOS replacements that are available? Or am I stuck making a new set for myself?
Oil cooler line replacement?
https://www.facebook.com/jason.baker.1614
1985 P43 Crown Vic, "Lightning Interceptor". Project is back on!
1987 P72 Crown Vic, EFI 351W (not my conversion), rusty and crusty parts car.
2006 Ford Fusion, 30MPG, premium sound, daily driver, 200K miles and still going.
2011 Ford Fucus, 36MPG, Sync, wifey / baby mobile.Tags: None
you could use the Push-lock AN hose. IIRC the hose is rated to 300*f and 300 PSIhttp://secondhandracing.com/Home.aspx
