does the 1986 have 2 oil plugs
    ive found one but is there another? i thought i remember reading somewhere that there was 2 plugs..
    thear is one on the front of the pan and on on the rear section of the pan. reason being that the pan has to go over the front frame crossmember witch breaks the pan into 2 sections...cant miss the two plugs!
      Yes, one's on the back part on the bottom, and there's one in the front in the middle by the bottom of the pan.
        also make sure your front drain plug has a drain plug gasket other wise oil will seep out
          got it, thanks guys.
