ive found one but is there another? i thought i remember reading somewhere that there was 2 plugs..
does the 1986 have 2 oil plugs
thear is one on the front of the pan and on on the rear section of the pan. reason being that the pan has to go over the front frame crossmember witch breaks the pan into 2 sections...cant miss the two plugs!
also make sure your front drain plug has a drain plug gasket other wise oil will seep out
