Recently my passenger door only opens from the inside but you still have to give a bit of a push to get it open. I've lubed all the parts but no luck. Is this a common problem with an easy fix? Thanks for your help....
Door trouble
Door trouble
1991 Grey Grand Marquis LS Sedan
61,000 Miles
1998 F150 XLT 4X2 Flareside Fire Engine Red
52,000 Miles
http://www.cardomain.com/id/hdlogisticsTags: None
well you should fist try to lube all the linkages for the locks and the lock its self too from outside of the door and from the inside og the door.
I lubed all the parts and the striker is in position. I'm guessing something has come loose inside the door. The door handle releases the door a bit but not enough to open completely. Will I have any problems removing the inside of the door to get at the parts?1991 Grey Grand Marquis LS Sedan
61,000 Miles
52,000 Miles
just don't yank too hard on the door panel, because if you do you will destroy the material that the anchors sit in. while its off to save yourself some trouble you replace the plastic anchors that fasten the panel to the doorSave a seal, club a liberal.
