i failed my ny state inspection cause of high hc how do i lower my hc levels
inspection
HC is usually running rich or burning oil. Do you have oil consumption problems? When was the last time you had a tune-up ? Is this an idle test, or do they test at some certain RPM or on a dyno or something?86 Lincoln Town Car (Galactica).
are your converters any good? How old are the oxygen sensors? Does it produce any codes? Timing correct?86 Lincoln Town Car (Galactica).
I'm one of those people that actually likes emissions testing. It keeps me from having to follow smokey stinky heaps that people refuse to fix properly. Of course I also favor competant and complete safety inspections for the same reason. I dont worry about my cars having ball joints fly apart and causing a pileup, its the other ones around me that I worry about.86 Lincoln Town Car (Galactica).
if you have a sefi car, it ought to have 4 converters. You're probably going to need working catalysts if your engine isn't really fresh. I've heard of low mileage motors getting through with no converter, but if your car has miles, its likely not going to get the job done.86 Lincoln Town Car (Galactica).
gotta have at least 2 cats to pass.....if one is hollow then that is a good explanation how you passed nox but failed hc
Originally posted by 86VickyLX View PostI think in NY they have tests that run cars on dynos up to highway speeds. The KR-86 or something like that.
