Ok, I checked many postings in the archives. I learned about many things regarding the 3g upgrade that Im planning on doing. Most postings go into detail about vehicles in the late 80's and 90's. I have a carbed 1982 302 that is stock. All I need to know is what vehicle or vehicles I can pull a used 3g from when I go top the U-Pull it place. I believe I have the large case 8.25 bolt spacing alt. see pic. Please advise. I have a friend with a 1994 ford taurus 3.8. His alt looks like it would fit. What do you guys think? Also, Will my pulley old pull go on the 3G??
3g alternator harvest.
Large frame alternators come from 3.8 Taurus, Continental, and Windstars. Small case ones come from 3.0 Taurus, or 3.8 Couger, Mustang, Tbird, and 5.0 Mustangs in 94-95.
Do you have a V belt or a mult-rib? If its the standard 6 rib, then the Taurus alternator has the proper pulley already. If you have a V belt, no idea if that pulley will swap, though I suspect it will.86 Lincoln Town Car (Galactica).
Will this work??? 6 rib and all.
Vehicle: 1965 Pontiac Catalina (fastback 2+2)
Chasis: 1982 Ford LTD Country Squire
Drivetrain: 302 V8 carb, AOD, 8.8 with 3.08 gears.
Big Brake swap and front suspension completed.
i have a polished v-rib pulley for a 3g alternator. came with the powder coated 3g that i gothttp://secondhandracing.com/Home.aspx
Originally posted by 82LTDQS View PostWill this work??? 6 rib and all.
http://www.partsamerica.com/ProductD...ype=11&PTSet=A86 Lincoln Town Car (Galactica).
