so today was the coldest day of the month, thus saying winter has come.a brisk 32*F.the car is in the garage as usual.i turn the key and and the fuel pump prime noise comes from the back as usual, but now, it stays on after i turn the key off.This happened last year when it got cold and it would turn off after like 10-15 minutes after i turned the car off it also turns off like that now.Im just wondering, whats the problem?i changed the starter solenoid a few months ago.Is it going to wear out something or drain my battery?
Why does it stay on?
Cold temps could easily cause the relay to stick.1990 Country Squire - under restoration
so i should replace it then.i went outside and turned the key and it stayed on, but this time i tapped the relay and it stopped lol.Is that wierd or am i just dumbsigpic-The Crown(Kodiak)1989,150K Miles,5.0LOpo,autolamps,slicktop,power windows and locks,yet still not good enough to be LX:confused:
yeah, tapping the relay un-stuck it. It needs to be replaced. Its probably a less than $20 part.86 Lincoln Town Car (Galactica).
