If you ever want to clean or replace your PCV screen I figured a way to remove it without pulling the upper plenum. The screen is located at the very rear of the lower intake manifold. Just remove the hose and attached valve (it pulls right ouit), then the rubber real bung (also, pulls right out). After that take a long (4-5") drywall screw and thread it into the screen material. Then you can use a pair of pliers to grab the screw and pull the screen out. If it is stuck, you can use a small amount of SEAFOAM or Carb Cleaner to free up the deposits, but don't overdo it, you don't want half a can of solvent thinning out all your oil when it seeps past ther screen.
My colony park had a 100% blockage, and my sedan with 80K mi. had a pretty much totally blocked screen as well.
A plugged screen can lead to higher crank pressures and burped gaskets. I hope that everyone likes my trick, it beats the ass off of pulling the plenum.
