Output Shaft in my AOD
    This reminds me of a random question: a few years ago, someone I knew slightly at the time was installing a torque converter on his AOD and didn't realize how precise you have to be in positioning the thing, so he took and whacked it with a hammer. No huge surprise, the car didn't go forward afterward. What exactly did he probably break?
      Originally posted by nfldfordltd View Post
      I'll get some pics when I get reunited with the car next week,
      I would like to see some pics still...
        I'd bet the pump. If that doesn't work, nothing works.
          The only thing I can take a pic of now is the piece of the output shaft that came out of the driveshaft yoke. I'll take it this weekend and post it soon.
          Just a wierd question: Has anyone else here had problems with the length of the Town Car driveshaft? When I took the driveshaft out of the car last October, the driveshaft was VERY difficult to come out. It seemed too long, and after the four bolts came out of the pinion flange, the driveshaft would not come ahead in the yoke far enough to drop it like those driveshafts are supposed to. It wouldn't clear the big pinion nut on the front of the differential. I had to pry and pound on it with a large hammer for a long time before it would come out.
          When I went to re-install it with the new transmission, I had the same problem, even though the new transmission is the "short" extension housing as opposed the the "long" extension housing on the original transmission. I ended up cutting about 1/2" off the driveshaft yoke (which made no difference as the yoke was "bottoming out" on the output shaft) and grinding the end off the pinion bolt in order to get it back in...and it still required the use of a large prybar and a hydraulic floor jack for re-installation.
          Does anyone have any ideas? I would like to cure this problem in case I need to remove the driveshaft in the future, though I hope I never need to remove the driveshaft any more...
            Was the rear axle at full droop? If so, it makes the DS harder to get out. Only time I ever had a problem is when the DS and output shaft splines were candy-caned and essentially locked together. I never did get those two apart, and the shop the car went to had a hell of a time as well.
              Probably just the pump, then? Is that something that he could have repaired at home instead of giving up and paying some goons $$$$ to put in a new transmission?
              Was that your Mustang? :p
                Nope, it was your P72, with the stupid harsh "hey look at me lose forward momentum" tire-chirping shifts, sticky tires, and intact Trac-Lock.
                The Mustang driveline was bulletproof. Low weight, low power, a low stall TC, sloppy shifts, and slippery tires
                I agree on seeing some pics. Odd to have the output shaft go before anything else.
                  Unless it had the wrong trans binding the driveline. And if it was that hard to get it may have been.
                  1989 Grand Marquis LS
                    If the car had been hit and the motor had been shoved backward, that might do it. The rear trans crossmember is not all that strong, so its possible to have that bend in an accident. One of our members went through that after a major front end wreck on his Townie.
