Hey guys...
For some reason I had 3 tranny fluid leaks this morning when I woke up... One on the upper line into the radiator (that one's fixed), and the other two are the two fittings that go into the tranny. With the nuts screwed in tightly, I can still wiggle the line around. I pulled them out of the nut (because they're that quick release type) and re inserted it to try to seat it better but nothing changed. Do I replace the nuts that screw into the tranny? And why on earth would both go at the same time?
Thanks for any help...
