Found a 93 t-bird (5.0) at the junk yard this weekend,and 93's have a cobra cam. Would the engine just be bogged down and run like crap in an otherwise stock ho conversion?(minus cam-my bro's B-cam was flat on two lobes) I've taken a ride in a friends black 93 t-bird and it got some real nice low torque,though he has some minor upgrades.
Cam question
So far as I know, all SEFI 5.0L Thunderbirds got the exact same "lowpo" cam and heads as '86-'91 5.0 Crown Vics, so for a performance build you'll be reusing basically the block, crank, and rods, and not a lot else.
The stock 5.0 Cobra camshaft wasn't really anything all that special, so I wouldn't personally go out of my way to find one as opposed to a '88-'93 Mustang GT cam.
How did your brother manage to wipe two lobes on a B303 camshaft? It's a hydraulic roller, and the lobes should in theory last forever unless the lifters suffered some sort of catastrophic failure ... or (*shudder*) someone tried to run the thing with flat-tappet lifters.2012 Mazda5 Touring | Finally working on the LTD again!
I almost bought a '91 LX that was a 5.0 HO.**2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 20K Cruiser
All the MN-12 5.0L T-Birds are HO. Should be good for a panther HO conversion.1990 Country Squire - under restoration
91-93 5.0 thunderbirds are high output......the cam will be nice in a speed density car
Originally posted by turbo2256b View PostIf i remember correctly on of the ford engineers told me the upper intake was modified to clear the hood of a bird and cost it 20 or so hp. ECM there fore might have a different calibration tthan say a ho mustang or mark 7
Also, I hear the exhaust is more restrictive, killing off some of the 20 HP as well.
The 92-93 Tbird cam is the Cobra cam, which will give you a bit more low end torque compared to a regular HO cam. It would run fine in an otherwise stock HO motor, just don't use that crapass Tbird upper intake.86 Lincoln Town Car (Galactica).
do not know, but probably86 Lincoln Town Car (Galactica).
yes
