tranny removal-any tips
    alright, tomorrow is supposed to be fairly bright and sunny for a change. and if i can find my jacks and such i'll start yanking chrsitines tranny. any useful tips or shortcuts? what size wrench do i need for the cooler lines? and should the car be on ramps or floor jacks?
    Save a seal, club a liberal.
    ok heres a few hints paul
    pick up a 16mm swivel socket and a 2 ft extension if u have one
    16mm is the bellhousing bolts, there are six of them
    ok theres 4 torque convertor nuts........i believe they are 14 or 15mm
    take the starter out and lay it aside......the two bolts are 1/2"
    there are a few bolts on the inspection cover take those out
    the friveshaft bolts are 12mm 12 point......if they were never out, they will be a biotch
    take the trans crossmember out.......jack with a board unser the pan now
    the crossmember can just be slid back
    unplug the speed sensor and the shift linkage and the backup light switch
    but some wood between the engines oil pan and the crossmember to keep the motor in place
    the cooler lines are 16mm i believe
    good luck and enjoy
    scott
      scott, you da man :thumbsup:
      i'll let everybody know how it goes
        you got the sizes wrong methinks...
        trans housing bolts should be 5/8"
        flywheel nuts are 9/16"
        LTD is still here
          and the most important one of all: unless you have some serious lift on the car for the swap, the tranny adapters for the floor jacks are useless
          '80 Town Coupé
            i was just gonna use a block o wood :coocoo:
              Oh yeah, feel free to comment, you fuckin monkey turd.
                i use my metric swivel sockets.......16mm fits perfect.......wtf do i gotta go buy a std set of impact swivels for :guns:
                  I can personally guarantee that Scott's (and Eric's) tools work perfectly for tranny swaps
                  '80 Town Coupé
                    its fucking raining again. and the last time i was underr a car in the rain i got sick for 3 weeks :cuss:
                      I used standard sizes on mine cuz thats what I had. I think the lines used an 11/16, or if you have one, a "quick" disconnect tool which is sure to take you far more time than the normal way. One other thing, unless you have some serious lift, you're gonna need to get out from under the car once the tranny is down and yank the dipstick tube. It just pulls out. Unless the trans is shit, you'll want to clean that area off and plug the hole with something to keep the dirt out. If its shot, well who cares? LOL
                        Use a 12 pt 12mm combo wrench and use another wrench for leverage.
                        Before you unbolt the tranny from the motor, let the tailhousing drop down with the crossmember out and drain your fluid. Insert your driveshaft back into the tranny and leave the driveshaft in the end of the tranny until it is on the ground so that any free fluid does not make a mess. As was mentioned, remove your dipstick tube and plug the hole first when unbolting from the engine.
                        Once you remove the nuts from your converter, push the converter in a bit so that it does not hang on your flexplate. It will only go in a small amount, but it will help.
                          i ogtta work tomorrow all day but monday i have off. assuming its fairly clear out, and not sweltering hot i'm gonna pull it. if theres a new thread called "Shifty Shifts!", i got the tranny in
                            is it possible to drop the tranny, and then remove the driveshaft or wuill that fuck things up. christine sank in the mud a bit and the only spot where i can safely jack the car up is in front now. theres no other room for a car that big in my yard
                              Nope, you can't remove the tranny with the driveshaft in. You have to pull the tranny away from the motor as you go down, and the driveshaft stops you from moving back. I had a cement floor to work on, but here is a trick to getting the tranny out from under the car. Use a 12"x12" piece of plywood, and old bed sheet (throw away kind). When you drop the tranny, lay the sheet under everything, and lay the plywood so that when you drop the tranny the pan lands on the plywood. Then get out from under the car and use the sheet to pull it out. Saves a lot of grunting under the car. If you have a full sheet of plywood, you could lay that down under the car to work on.
                              Drain all the fluid out before you drop it. (Note: You can't really drain ALL the fluid just most of it. So after your done draining anf it doesn't drip any more, don't think that it is empty. It has plenty more throughout the system that can't drain while it's level and not running.) To drain torque converter, on the front of the tranny is a little shield, take it off and you'll see the flywheel. Turn the engine till you see a smaller bolt that goes to the torque converter. Take it out to drain the fluid in it.
