^^^^ thats what i was htinking when i got my E cam. though all i heard was how the E cam was a low end power cam so i got it anyways. i guess i got suckered in but it didnt help when i got the cam for 50 bucks.
Need a better cam
Originally posted by OVERKILL View PostMy cam comes on like a light-switch, but definitely doggy below ~2,000RPM, comes on hard north of 2,500RPM.
Take the descriptions of the FMS alphabet cams with a grain of salt......... They have a 2,800-3,200lb Mustang with a stick in it in mind when they make those recommendations......
Well past where my tranny shifts at this point1989 Town Car Cartier: 3G Alt. Upgrade, Mark VIII Electric Fan, Police Interceptor Suspension, 40-series Flows, loaded. HO+ Conversion: E7 heads, Cobra 1.7RR's, Explorer intake, 65mm TB, FMS "E" Camshaft, 4-hole 19lb/hr injectors, A9P ECM, 76mm C&L MAF, BBK CAI. 338,000Km, stock bottom-end.
if you're running stock valve springs, it will most likely valve float before the cam completely runs out. 5500 is the advertised top end for an E, and that sounds about right. Stock springs will probably float in the 5500-6000 range, and the stock rev limiter is 6250, so you're not getting past that anyway.86 Lincoln Town Car (Galactica).
Without a tuner or a chip anyways1989 Town Car Cartier: 3G Alt. Upgrade, Mark VIII Electric Fan, Police Interceptor Suspension, 40-series Flows, loaded. HO+ Conversion: E7 heads, Cobra 1.7RR's, Explorer intake, 65mm TB, FMS "E" Camshaft, 4-hole 19lb/hr injectors, A9P ECM, 76mm C&L MAF, BBK CAI. 338,000Km, stock bottom-end.
Yup. I have one for my Capri. Couldn't justify the expense on the Townie though. It's not a race car.......1989 Town Car Cartier: 3G Alt. Upgrade, Mark VIII Electric Fan, Police Interceptor Suspension, 40-series Flows, loaded. HO+ Conversion: E7 heads, Cobra 1.7RR's, Explorer intake, 65mm TB, FMS "E" Camshaft, 4-hole 19lb/hr injectors, A9P ECM, 76mm C&L MAF, BBK CAI. 338,000Km, stock bottom-end.
Originally posted by gadget73 View Postif you're running stock valve springs, it will most likely valve float before the cam completely runs out. 5500 is the advertised top end for an E, and that sounds about right. Stock springs will probably float in the 5500-6000 range, and the stock rev limiter is 6250, so you're not getting past that anyway.
Originally posted by import convert View Postwhat about mustang valve springs? but yea if the cam is too radical floating a valve is inevitable
TFS makes a spring kit that fits stock heads. It's cheap and a great upgrade for any mild aftermarket stick.1989 Town Car Cartier: 3G Alt. Upgrade, Mark VIII Electric Fan, Police Interceptor Suspension, 40-series Flows, loaded. HO+ Conversion: E7 heads, Cobra 1.7RR's, Explorer intake, 65mm TB, FMS "E" Camshaft, 4-hole 19lb/hr injectors, A9P ECM, 76mm C&L MAF, BBK CAI. 338,000Km, stock bottom-end.
Yes, quite likely. You'll know it if you put it on a dyno and the graph turns into Bart Simpson's hair past a certain RPM point.1989 Town Car Cartier: 3G Alt. Upgrade, Mark VIII Electric Fan, Police Interceptor Suspension, 40-series Flows, loaded. HO+ Conversion: E7 heads, Cobra 1.7RR's, Explorer intake, 65mm TB, FMS "E" Camshaft, 4-hole 19lb/hr injectors, A9P ECM, 76mm C&L MAF, BBK CAI. 338,000Km, stock bottom-end.
These heads were rebuilt with new springs. I have no idea what they are other than they are heavier than stock.
THESE are the ones I was talking about from TFS:
