Hello all. New member. Glad I found you guys! Recently picked up an 88 country squire. Love her to death, but I'm having 2 issues.
1. She overheated. Bad. Stalled, but didn't lock up. Apparently the thermostat was older than dirt and failed (one half had oxidised to the t-stat housing, the other broke loose and lodged itself into the intake...), blew up the radiator. Got those fixed, and found the head gasket had failed. Fixing to dig into that, but the tc we has previous had the 4.6, and I'm unfamiliar w/ the 302. Anything to watch out for or check while I'm rippin her guts out?
2. The aod learned a new trick. No first gear (I assume this would be "slip" but id feels more like it's stuck in neutral) when moving from stop for a second or 2 when in OD. Doesn't happen when in D. A wiggle to the shifter is greeted with a thud into forward motion. I know I need to do a complete flush & filter, as the fluid is amber/brown and smells like brake fluid. That can't be doing good things. Any known internal/mechanical issues that does this?
Engine also starts to bog after running for a bit, but I'm figuring that's from fluid loss. New ignition coil, pickup coil, and module are in the works too. Look like orignal pieces, and I don't really trust 20 yr old electronics...
Thanks in advance. You guys have a great resource here!
