hey all im new to this board but Ive been on lincolns online and crownvic also. My problem is that i cant get the belt for the AC and air compressors back on. the tension seems to be too high to put it around the tensioner pulley then try and match up the holes to screw the pulley back in, and its too hard to bolt down the tensioner pulley then try to manuver the belt around it. how do you guys do it?
HELP, i cant get the AC belt back on my car!
you know the tensioner will pivot back and forth right????Pete ::::>>> resident LED addict and CFI defector LED bulb replacements
There is a 9/16" nut (if i remember right) on the back side of the plate that allows the tensioner pulley to be repositioned. It is much easier to access if you remove the smog pump permanently, but then you'll need a shorter belt.1991 GM GS sedan "Love Boat" HO converted, Holley adjustable fpr, 3.27 Trac-lok - RIP
1991 Colony Park LS "Wally World Express" HO, 3.27 trac-lok - RIP
1988 grand marquis ls "grey ghoul" - RIP 1992 gm ls "superbeater"- sold 1993 F350 dually 7.3 IDI crew cab flatbed "killer" - RIP
1994.5 F350 Dually Crew Cab Flatbed, Powerstroke 7.3 "overkill" - Alive and kicking
1987 Lincoln Town Car "El Presidente" - Resting for winter, gonna be a beast!
2008 Mustang, no name - belongs to the wifey
take the bolt out of the back of the tensioner, pivot the tensioner so you can install the belt, and put the bolt back in and tighten the belt
welcome to gmn......we can always use more towncar owners over here!
scott
:stupid:
There also should be a square hole that will take a 1/2" ratchet/breaker bar so you can tighten the belt up.86 Lincoln Town Car (Galactica).
thanks for the help, i got it on by swinging my ac compressor down a bit and using a crowbar. Ill have to look for the pulley tensioner adj bolt, it sure looked stationary to me. I'm also going to do the HO conversion this summer, which i am looking forward to.1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
Originally posted by gadget73:stupid:
There also should be a square hole that will take a 1/2" ratchet/breaker bar so you can tighten the belt up.\'05 Suzuki GSX-R - Daily Driver
\'87 Ford Crown Vic Country Squire - Sad to see her go
\'87 Mazda RX-7 - 302 project
Yeah.... it\'s stock. =)
there is one on mine. i don't have the old one to take a pic of but its on the new one too. i think its between the pivot bolt and the tension bolt IIRC, you'll have to feel around for it. need a short extension too.86 Lincoln Town Car (Galactica).
