starter solenoid
    starter solenoid
    can anybody show me a picture of how the wiring on the starter solenoid goes?mine is on the fender well and i think i hooked it up wrong because everytime i hook the positive cable back up to the battery either a fuel pump sound comes on , and stays on until i take it off,or the starter cranks the motor like im jumping it.help please
    sigpic-The Crown(Kodiak)1989,150K Miles,5.0LOpo,autolamps,slicktop,power windows and locks,yet still not good enough to be LX:confused:
    heres a picture of how I setup mine. Lucky I just put these up recently because my car wasn't starting.
    Starter wire goes by itself on the left terminal, as can be seen here, everything else, the right terminal, and finally the ignition sensor L-shaped wire goes to the top terminal.
      thanx a lot mang u just fkn saved my life lol
        If there are more than one small terminals on the solenoid, and you only have one small wire in the harness, it goes on the S terminal.
          yea i remembered where that small wire went.wats the I terminal for?
            ignition power for older cars. It bypasses the ballast resistor to give full power to the coil while cranking.
              oh ok that makes sense.thanks a lot guys
