Sweet, glad you got it figured out!
no start condition persists....
Spark is usually something charging up. Do you have a big stereo amp? Capacitors charging will do that. You should see mine with that 1 farad cap in the trunk. I actually charge it through an 1156 lamp to keep it from doing that.86 Lincoln Town Car (Galactica).
Could it be a fusable link within one of the wires???? Geeeez nice camera bro. those pics are so freaking clear, I thought I was under your hood.Vehicle: 1965 Pontiac Catalina (fastback 2+2)
Originally posted by 82LTDQS View PostCould it be a fusable link within one of the wires???? Geeeez nice camera bro. those pics are so freaking clear, I thought I was under your hood.
Thanks for the info on that spark, I do have a 600 watt amp in the trunk and I bet thats what did it.1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
