no start condition persists....
    Sweet, glad you got it figured out!
      Spark is usually something charging up. Do you have a big stereo amp? Capacitors charging will do that. You should see mine with that 1 farad cap in the trunk. I actually charge it through an 1156 lamp to keep it from doing that.
        Could it be a fusable link within one of the wires???? Geeeez nice camera bro. those pics are so freaking clear, I thought I was under your hood.
        Vehicle: 1965 Pontiac Catalina (fastback 2+2)
          Id wrap that alt output connector so it doesnt short. That looks like some sparkage waiting to happen
            Thanks bro, its a newish sony cybershot
            Thanks for the info on that spark, I do have a 600 watt amp in the trunk and I bet thats what did it.
