New Alternator
    New Alternator
    Hi Guys, it's been a while!
    First off I'd like to thank the many that contributed masses of information on the 3G alternator swap. I've just purchased a brand new 3G 200Amp and put it on my 88 gm. I no longer use the shabby factory output wires and installed my own 4 gauge wires from the alt to the 12v terminal on the starter solenoid and from the ground bolt on the alternator casing to the fender.
    Man what a difference! My GM is now charging at 14.5v at idle. Even with all the accessories on like the air, lights, defroster, amp, it doesn't drop below 13.8v.
    Once again guys thanks for the info and finally my advice to anyone thinking about doing a 3G swap, don't think about it DO IT!!! the results are astonishing and all told the swap from start to finish, including my 4 gauge wires took me about an hour!
    Regards
    Danny
    2002 Mercury Grand Marquis GS 4.6L V8, 1988 Mercury Grand Marquis GS 5.0L V8, 1979 Lincoln Mark V 6.6L V8, 1977 Lincoln Continental 7.5L V8, 1999 Chevrolet Suburban LT 5.7L V8
    Really glad everything worked out well for you, and more importantly the car is a lot safer and reliable now. After replacing my 2g with yet another brand new 2g two years ago I figured I'd be alright. During this past winter, it of course died and me and my Dad did the 3g swap and I know get 14.8 volts at idle. After the upgrade, you really realize how simple it is.
    1986 Grand Marquis LS 2 Door
      If it'll make the car less of a rolling fire hazard, I'm all for it. I mostly did it for the stereo I'm planning, but the headlights are sure brighter.
        I'm another post-fire convert. Alt fried on the way to a meet and the car died in the middle of the road in Northeast Philly. I had someone run over to jump me so I could get into the parking lot. Rigged it back together enough to get to a friend's house and with Scott's guidance I had a 3g on the car to get me home.
          Im glad we were able to make it painless for you!! thats what we're here for!!!
