Today I jacked the rear up. With tranny in park, I spun one wheel, and the other didn't move... then I did the same to the other side, and the same thing happened. Yet, today, again I left two nice marks.... Even Jason91gm drove it and it did it. for broken rear ends that turn themselves into lsd units. hahaha
LSD in a WAGON?!
Originally posted by Jason91GMi think the crazy fucker already chewed up the spider gears and they have "welded" together. crazy bastard.http://secondhandracing.com/Home.aspx
Originally posted by qazvickToday I jacked the rear up. With tranny in park, I spun one wheel, and the other didn't move... then I did the same to the other side, and the same thing happened. Yet, today, again I left two nice marks.... Even Jason91gm drove it and it did it. for broken rear ends that turn themselves into lsd units. hahaha
i got the lamewad 2.73s...
anyway check your tire sizes... the way i did it was by adding a smaller tire on the left side. since traction always tends to goto the right wheel, i'd figure i put less resistance on the right, i can get both to spin. sure enough, both span.
i would suspect that, or a trac-loc upgrade.LTD is still here
They are definately matching tires. And I doubt it's an upgrade because I can't get it to break the ass end loose in the middle of a u turn. So... like Jason91gm said it's prob a wasted rear end with "welded" spider gears.\'05 Suzuki GSX-R - Daily Driver
\'87 Ford Crown Vic Country Squire - Sad to see her go
\'87 Mazda RX-7 - 302 project
Yeah.... it\'s stock. =)
