Ok I just got done installing a 180* thermostat and a brand new waterpump and flushed out the radiator. All that changed with that was that it took a lot longer to heat up, but once the thermostat opened it steadily climbed 190-195-200-205-210. Then I just let her idle at 210* and she cooled back down to 200* and stayed there. So I took her out for a drive and it just kept rising all the way to 225* with no signs of stopping. Heat was on full blast, coolant full. Head gasket on backwards guys? or do I just need time, patience, and a mark VIII fan and dual core radiator?
overheating problem updates
not sure if this applies to all gaskets, but with Fel Pro head gaskets you'll see a tab of gasket material sticking out at the front corner of the motor between the head and block. Its right near the lower, front most head bolt. If you've got a tab only on one side, the gasket is quite possibly backwards.86 Lincoln Town Car (Galactica).
Ahh I have felt pro! I shall check that tomorrow. I know i have a tab on the drivers side tho.1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
The head gasket tabs stick out on both sides in the front, so it must be the cooling fan and radiator not up to par. I'll try the Mark VIII fan and a cooling flush before I change the radiator. It is a stock radiator, single core.....could that be it?1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
fan was cross-wired runs 180* now1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
it blew instead of sucked? That would do it when moving.86 Lincoln Town Car (Galactica).
Just make sure you are using a good, reliable fan controller. Word of advice: The $35 controller from Autozone is shit. I had 3, count them three, fail on me. I overheated my stock 351 pretty bad on the last one. I currently have a DCControls 50-amp unit awaiting installation.sigpic
https://www.facebook.com/jason.baker.1614
1985 P43 Crown Vic, "Lightning Interceptor". Project is back on!
1987 P72 Crown Vic, EFI 351W (not my conversion), rusty and crusty parts car.
2006 Ford Fusion, 30MPG, premium sound, daily driver, 200K miles and still going.
2011 Ford Fucus, 36MPG, Sync, wifey / baby mobile.
she's driving great now! Lotsa more power and no leaks!1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
Originally posted by Heretic View PostJust make sure you are using a good, reliable fan controller. Word of advice: The $35 controller from Autozone is shit. I had 3, count them three, fail on me. I overheated my stock 351 pretty bad on the last one. I currently have a DCControls 50-amp unit awaiting installation.86 Lincoln Town Car (Galactica).
yeah, the last one i had on there that was built in with the proform fan blew and I heated up a while back. how many relays should be installed?1989 Lincoln Town Car - "Anabelle" - Original block, .030 over with SpeedPro pistons, rods fitted with ARP hardware, FRPP +volume oil pump, GT-40 3bar heads, Crane 1.72 rockers, 89' Fox cam, 93' Cobra lower intake, Explorer upper and 65mm TB, 93' Lightning EGR spacer, K&N intake kit from a 4.0L Ranger, 19lb/hr injectors w/ 87 Mark VII ECM, cat/smog deletes, Big Brake conversion, 3.55 K-Code Trac-Lok/Disc brake rear axle, CVPI LCA's w/1" sway bar in rear, wagon front sway bar, BBK 2.5" off-road H-Pipe, Flowmaster super 40s, HPP wheels, 3G alternator w/LMR.com wiring kit, gear reduction starter conversion, Best 1/4 time: 16.0 @ 85mph.
They are not closed, they just changed the way they do stuff. I went here: http://www.dccontrol.com/0820.htm and surfed around until I came to the order page, then ordered, Paypal'd, and waited about 2 weeks.sigpic
Originally posted by 89LincolnTWNcar View Postyeah, the last one i had on there that was built in with the proform fan blew and I heated up a while back. how many relays should be installed?86 Lincoln Town Car (Galactica).
