As you may recall, a new motor was recently installed in the '90 GM. Lopo 302 with E7 heads. It's been gone through quite thoroughly a few times, now, but still has a few issues which bother me.
The shop that did the motor says it's mechanically sound and there should be no issue. I've replaced O2 sensors, IAC valve, and fan clutch since I've had the car back. The following issues still remain: 1. engine shudders at idle (in gear and in neutral); 2. engine temp is running around 205 deg. F. to 215 deg. F.; 3. I've adjusted the TV pressure, yet the car doesn't seem to have the "get up and go" that it should; 4. when I put my ear to the tail pipe, I can hear a slight "pthh" in a rhythmic pattern (when car is at idle).
The shop is 120 miles away, so I'm not able to "just run it back" due to fuel costs. Anyone have any input on these issues? Is it possible that the Lopo cam and E7 heads don't agree with each other? I'm at my wits end with this car, and my mom is not happy with the rebuild. Seriously, it had more "pep" on the original Lopo with the horrible bottom-end knock.
