removing rear seat
    removing rear seat
    does the lower part just pop out or what??
    do you pull out, then lift up???
    any tricks to re-install???
    yes.
      I believe that you have to push down, then back to remove it. There should be two hooks underneath. Install should be the reverse. I'm not 100% sure.
      Justin
        to remove the rear seats
        push in hard on the lower seat bottoms........this releases the frame from the clips on the body
        the rear upper can be a pita........you need a t 55 socket or three, a can of blaster, a breaker bar lots of patience........careful not to round out the torx bolts, and dont bust a nut! two little tin straps hold the seat to the car at the bottom along with the seatbelts. then lift up on the rear seat and pull it out
        good luck!
        scott
          T55!!! I thought it was T50... Ill have to upgrade my tool supply!
            I think it is T50...
            You just have to remove the outer 2 with the metal straps like scott said.
            '95 Ford Bronco XL -
            sigpic :rebel:
              it might be a t50 i sawry
                Good luck gettin em out. Just ask Scott about the ones in my Vic! I ended up cutting the damn metal tab, couldn't get the bolt out on one side. He worked up a sweat that day I think, heh.
                sigpic :rebel:
                  one of my doors wouldnt open when i first got my car, so i had to take out the rear seat to get the door panel off.... the selt belts were long enough that i could get it out of the way without pullin the belts. so if the seat doesnt have to leave the car completely, dont mess with the belts.
                  grand_marquis_gt: "Wow dude, you got the GMGT sedan!"
                  there, now im cool too
                    ok so I got the bolts out no prob, no lube needed
                    BUT I cant seem to get the bottom of the seat to sit all the way down, like its not locked in. I ment to ask for assistance at Scottfest but my back seat was so full o f stuff I didnt think about, I guess cuz I didnt see it floppin'.
                    I tried pushing down and back, pushing down and pulling, but it allways leaves it just a little bit loose on the edges.
                    How'd you guys snap yours back in???
                      i had a big fat chick sit on mine, but then i needed new shocks
                      Save a seal, club a liberal.
                        Push real hard. You may bust a nut doing it
                        1989 Grand Marquis LS
                          I literally beat the piss out of mine 'til it went back in...
                          "If I owned Texas and Hell, I would rent Texas and live in Hell."
                          -Gen. Philip Henry Sheridan
                            Make sure the hook on the bottom of the seat goes into the C shaped thing sticking up off the floor. Unless that bar sits in the C on both sides, it won't stay in place. Also might want to make sure the ears on that thing aren't bent up. Mine were bent up a bit and the seat didn't sit firmly down.
                              lol - the hooks are definitly in, Ill try bending them down a little. I sat down on both sides and did some serious thrusting but to no avail
