ok so i hooked up the new alternator, it wasnt puttin out a charge. took it to the auto part supply, tested good. so i put it back in, no charge. so i fiddled with everything, tried everything i could think of, no charge. i tested a few things and my results were as follows:
10 gauge wires are connected to the battery
yellow wire is suppling 12v to the regulator
stator wires are making full contact.
there is NO output, from either alt, car idles for about 5-10 minutes, with no lights on, on a jump start, then dies.
so after getting annoyed with it, i reconnect the wires and put the old alternator back in.... NO CHARGE! no output from either alternator. i think something may be wrong in the harness or something. any ideas?!?!?!?! thanks!
