oil pan
    oil pan
    what aftermarket oil pan would fit my 87 cv wagon looking for more capacity
    and whats the difference between front and rear sump pans and which one should i get
    you want a rear sump. Look for stuff for a fox body Mustang, its the same pan. Don't really need more capacity unless you're building a lot of motor. Stock motors are fine with 5 quarts.
      im running a Canotn 7qt. rear sump for a 351 mustang
        most fox pans should fit.
          ok thanks
