Ok kids. I am officially an ebay addict. I have my 1993 Thunderbird motor and trans (I know the trans is too short, but it should be a good core). I even have the GT40P heads. They are in the mail. If anyone has any tips from similar transplants, I'd like to hear from you. I am stil shopping for a new roller cam. Comp Cams has one that looks good. With a little advance I think it will be prefect. Lower stall and low end torque is the goal.
I am hoping the wiring harness is reuseable from the Thunderchicken. I need an ECM yet and some headers. I want to get the heads rebuild before I get the pisons picked out. I want to get a set of roller rockers too. Kind of getting one thing at a time to make sure it all fits.
I need to measure the accesory mounts from the bird as well. I want to use them and relocate the A/C like it is on the birds. Then I won't have a clearance issue for the mass air. That is if it fits. Then I can use more Mustang stuff like the underdrive pullies, etc.
Has anyone else on here swaped out the AOD guts to the newer style tans? I like the idea of having the lower 1 and 2 gear so you don't have to have such a low rear end. I also like the better OD band. I am thinking 3.27:1 is the ratio back there for good launches, but respectable fuel economy. I want to get low to mid twenties for fuel economy.
She's coming together, I just want to save myself some grief if I can learn from your experience.
