I just put the shortblock in Anabelle today. Got the motor mount bolts torqued and the torque converter to starter plate nuts hand tight. How tight should the converter to flex plate nuts be? 50 ft/lbs ok? Also is loctite a good idea on those nuts? Tomorrow i should be intstalling the starter and torquing the bellhousing to the block bolts, then porting my heads a bit, by grinding the egr bumps off.
got the motor in
got the motor in
20-34 ft/lb per the book. you should actually use new nuts on those if possible, they're a jam nut. Failing that, loctite works.86 Lincoln Town Car (Galactica).
Wow. I never replaced the TC nuts and I had them off/on several times. Learn something new every day (if we're lucky.)
I always go almost a full grunt on the TC nuts. Not soft, but definitely not too hard. Last thing I ever wanted was to rip off one of those studs...
Good luck with the rest of the engine build, man... but didn't you just do this three or four years ago?2011 Mustang GT Premium, MT82, Kona/Saddle, HIDs, 3.73s, 19s, hood/side stripes, UPR 1.5" springs with adjustable panhard bar, and UMI solid LCAs and relocation brackets.
oh i've never replaced mine either, used a torque wrench on them, or used loctite but I never tell people what I do with my own junk lol.86 Lincoln Town Car (Galactica).
