225* isn't gonna do anything.
the stupid "engine" light
Possible, but it could well be a clogged radiator. If its original its probably crusty inside. Thermostats are cheaper tho.86 Lincoln Town Car (Galactica).
change the thermostat first.....they are cheap.........if no improvement, change the radiator......they get all full of junk after 20 yrs
Thermostats are cheap, but you can check it and make sure it's working by dumping it in some boiling water with an instant-read cooking thermometer in the water. You can watch it open and close if you take it out with some tongs and then put it back in. It's also cool just to watch for the hell of it, if you have to pull the t-stat.Originally posted by gadget73There is nothing more permanent than a temporary fix.
Testing a new one before installing it is also a good idea, they have been known to be defective out of the box.86 Lincoln Town Car (Galactica).
My "check engine light" came on last week.... 1990 CV 5.0 The car never runs hot and actually I think it runs on the cool side. Just a day or so before the light coming on I replaced both serpentine belts and had the alternator rebuilt. THe old belts were worn out and slipping. The new ones are on good and tight.
The check engine light only comes on at idle and goes off when accelerating. I wonder if the engine RPM had dropped at idle because of the tighter belts ... Any ideas ?
Regards
Doug
Sound like you have low oil pressure.~David~
The car runs fine, does not smoke or anything, good power. I thought it might have something to do with the idle screw needing adjustment ...... It is the orange light that came on from the computor. I thought the red engine light had to do with low oil pressure ...
cheers
Oooh, it's fuel injected?
I thought the computer light was only supposed to come on when it's throwing a code - meaning, it comes on and stays on until the code is cleared.2012 Mazda5 Touring | Finally working on the LTD again!
If it's a 90, you have an actual oil pressure light which is red and shaped like an oil can. If your YELLOW "Check Engine" light is coming on, you need to pull codes.
87CP--the EFI computer will often set codes and not put the light on.
On OBD-II cars (post 1996), the check engine light will come on when it sets a code and leave it on until the code is cleared, but Ford's EEC-IV is just stupid like that.Originally posted by gadget73There is nothing more permanent than a temporary fix.
my money is on TPS, but check it for codes to find out.sigpic
